/webconsole/api/v2/MediaAgents status and offlineReason codes
  • August 17, 2023
  • 362 views
The GET V2 MediaAgents API has some numeral codes for offlineReason and Status which seem to reflect some different senarios.  I have seen 0, 1, 2, and 5.  Usually there is documentation coving these things but I not finding it in the online documentation.  Do we have a link to this info?
            "offlineReason": 0,
            "description": "",
            "status": 1,
            "mediaAgent": {
                "mediaAgentId": 2,
                "_type_": 11,
                "displayName": "dm2perf3",
                "mediaAgentName": "dm2perf3"
            "osInfo": {
                "osId": 210,
                "OsDisplayInfo": {
                    "OSName": "Windows Server 2016 Datacenter"
            "versionInfo": {
                "UpdateStatus": 0,
                "GalaxyBuildNumber": "11",
                "GalaxyRelease": {
                    "ReleaseString": "11 SP17",
                    "_type_": 58,
                    "ReleaseID": 16
            "mediaAgentProps": {
                "pushMA": false,
                "isPreConfigured": false,
                "isUnlicensedMA": false,
                "isVirtualsClient": false
            "powerManagementInfo": {
                "isPowerMgmtAllowedCheck": true,
                "isPowerMgmtSupported": false
                "mediaAgentName": "yashdutch"
            "osInfo": {
                "osId": 210,
                "OsDisplayInfo": {
                    "OSName": "Windows Server 2012 R2 Datacenter"
Best answer by G2T
Commvault provided via iternal documentation.
Please find the MA offline reasons below, and description of the error accordingly
HOST_STATUS_DEFAULT = 0  No errors detected
HOST_STATUS_CONNECT_FAIL = 1 Cannot communicate with Media Mount Manager Service/ Please ensure that / The MediaAgent is reachable from CommServa and All MediaAgent services are running.
HOST_STATUS_VERSION_MISMATCH = 2 The CommServe and MediaAgent versions appear to be different. They must be the same. Please upgrade your MediaAgent.
HOST_STATUS_MARKED_DISABLED = 3   The MediaAgent has been marked as disabled.
HOST_STATUS_OLDER_VERSION_AND_PAST_GRACEPERIOD = 4  MediaAgent has been marked disabled as it has exceeded the pre-determined number of days since the CommCell has been upgraded.
HOST_STATUS_INITIALIZING = 5  The MediaAgent is initializing and refreshing the device information.
HOST_STATUS_MIGRATED = 6  The MediaAgent has been migrated to different CommServe.
HOST_STATUS_POWER_MANAGED_VM = 7  This Media Agent is powered off by Power Management.
HOST_STATUS_NODE_REFRESH_ERROR = 8  Media Agent marked offline as node refresh failed, please check logs and retry the operation
HOST_STATUS_SMART_STATE_MANAGEMENT = 9  MediaAgent is marked offline by the automated MediaAgent state management feature.
HOST_STATUS_CVFWD_DETECTED_OFFLINE = 10  Cannot communicate with Media Mount Manager Service./ Please ensure that  The MediaAgent is reachable from CommServe. and  All MediaAgent services are running.
  • August 21, 2023
  • August 22, 2023
@G2T where did you find/get this information?
Please share the link to where this is documented. Thanks!
  • August 28, 2023
Commvault support.  As far as I can tell, this info is not currently available in any public location.
  • August 28, 2023
I requested above to be documented.
