Workflow for pushing network configuration to client
  • August 29, 2023
  • 106 views
I need to create a workflow that performs push network configuration to the client. Do any of you have such a workflow and could share it with me, or is anyone able to direct me how to do this? Thank you very much in advance for your help!
Forum|alt.badge.img+8
@lradzki,
I checked the commvault store, but I did not find a workflow that performs push network configuration to the client
You can alternatively use below REST API to push the network configuration:
https://api-next.commvault.com/docs/api/cv/NetworkTopologyOperations/push-network-configuration#push-network-configuration
  • August 31, 2023
Thank you, I will try to use REST API
