Workflow to resubmit the failed jobs
  • January 20, 2025
  • 128 views
Hello Guys!!
I’m looking to create a workflow to auto submit the failed jobs post performing the basic prechecks like ping the client, check connectivity, CommVault services.
Can anyone guide me it’s my first step towards making any workflow.
  • January 21, 2025
Hi ​@Shiva Chaudhary ,
Kindly refer below document to create custom workflow and there are few pre defined activities which can be referred for creating the required activities.
https://documentation.commvault.com/2024/essential/creating_business_logic_workflow.html
https://documentation.commvault.com/2024/essential/predefined_activities_for_workflows.html#job
  • June 4, 2025
I’m looking to create a workflow to auto submit the failed VM backup jobs
Is there any existing workflow for it. Kindly share.
  • June 5, 2025
Hi ​@Harshit ,
As of now, there is no default workflow available within Commvault for VM job resubmission.
However, you may refer to the document below to create a custom workflow match your environment
