DDB setting with two site
  • May 10, 2024
  • 69 views
Forum|alt.badge.img+5
Hi All,
Refer below environment, may we know about DDB setting pros and cons? e.g. before failover and after failover for DDB dedu ratio enhance, performance, resilience…..
HA setting SiteA commserve master and SiteB commserve standby
setting A use different DDB path location
  • siteA data primary backup to siteA local DL1 with local SSD DDB1, second copy to siteB local DL1 with SSD DDB1
  • siteB data primary backup to siteB local DL2 with SSD DDB2, second copy to siteA local DL2 with SSD DDB2
setting B use same DDB path location
  • siteB data primary backup to siteB local DL2 with SSD DDB1, second copy to siteA local DL2 with SSD DDB1
Best regards
Forum|alt.badge.img+9
  • May 10, 2024
Hi Chinchilla,
is the Commserve acting as a media agent ?
is the DDB disk shared between the master and standby commserve ?
If we know answers to above question, we can help you
Suleman
  • May 11, 2024
Hi Suleman,
siteA physical server Master with MA for dedu and backup destination, siteB physical server MA only for dedu and backup data destination, siteB standby commserve is VM for failover only
Should be no, master and standby in two site via slow wan link, I have no idea any benefit
Best regards,
Chinchilla
  • May 14, 2024
Hi Chinchilla,
Suleman
Hi Suleman,
Best regards,
Chinchilla
