Erro restore de FS com erro [Error Code: [14:286] Description: Index reconstruction failed. Reason [Restore of Index]
Description: Index reconstruction failed. Reason [Restore of Index logs failed from media [lenovo_disklib2 ]. Please check whether media is in library and retry.].
Source: baas-media04, Process: Browse
Dear!
This is a file system restore (dump_log) that is failing at 5% completion. Previously, we had conflicts with backup jobs running on the same server, so I created a Blackout Window schedule to prioritize the restore. However, I have a DDB_Reconstruction job running, which I believe might be causing the conflict. This is why it's generating this failure. Could you please validate this?
Sirlene
Forum|alt.badge.img+2
Hi ​@sirlene.castro
Based on the error code [14:286] and description, the restore is failing because the index logs required for the restore cannot be restored from the media [lenovo_disklib2]. The error specifically advises to check whether the required media is present in the library and retry the operation.
--> The restore job is failing at 5% due to missing or inaccessible index logs on the specified media.
--> The error is not directly caused by the DDB_Reconstruction job, but by the inability to access the required media for index reconstruction.
--> If the required media(probably a mountpath) [lenovo_disklib2] is not loaded or available in the library, index reconstruction and restore operations will fail.
Could you please ensure that the media [lenovo_disklib2] containing the index logs is physically present and loaded in the library?
Kalaivanan.
Hi, Kalaivanan!
Thank you very much for your insights and for taking the time to look into this issue.
Your explanation was very helpful and gave me a good direction for further investigation.
I really appreciate your support.
Sirlene Castro
