File System Backup job is not running Properly.
  • Mar 4, 2025 7:26 AM UTC
  • 94 views
Forum|alt.badge.img+2
I created three subcient in file system and created schedule policies. But backup job is not running as per their schedule policies. job history is not found there of all backup jobs.
I have attached some images. Please check this and tell solving process.
Best answer by Rajiv
Hello ​@Zumshedul Abedin Chowdhury If you look at the schedule it clearly states starting March 7 and november 1 which means the scheduler will initiate a backup from this respective date. Kindly make changes to the schedule and start it from today.
Best,
Rajiv Singal
Rajiv
  • Mar 4, 2025 7:51 AM UTC
Hello ​@Zumshedul Abedin Chowdhury Can you check the job controller to see if the jobs are still running and not yet completed?
Best,
Rajiv Singal
Hello ​@Rajiv
In Job controller showing there are no jobs controller running.
Image is given below:
Rajiv
  • Mar 4, 2025 8:35 AM UTC
Best,
Rajiv Singal
Hello ​@Rajiv
Problem solved.
Thanks.
