Problems trying to register clients
  • March 11, 2025
  • 504 views
EJIE
Apprentice
Forum|alt.badge.img+5
I have clientes with commvault agent installed but no register on commcell. When i try register the client with the option “Fetch the configuration information from the client that is already installed in deocupled mode”.
from the client's cvfwd.log log file i see that following
6416 07a0 03/11 12:17:10 DT:00043 CN:92536 [COMMSERVER_ID->CLIENT_HOSTNAME:cvd] ERROR: Client connection failed on CLIENT_NAME: No direct tunnel to CLIENT_HOSTNAME
6416 07a0 03/11 12:17:19 DT:00044 CN:92538 [local->COMMSERVER_ID:AppManager netw] Successfully completed client connection {afcbd2b3-ae18-b5a3-2f6e-12e4be337e94}
6416 07a0 03/11 12:17:50 DT:00044 CN:92539 [local->COMMSERVER_ID:AppManager netw] Successfully completed client connection {455e23f1-a693-5152-5a2e-4a1dc262f5f4}
the client port 8400 is listening
netstat -ano |findstr 8400
  TCP    0.0.0.0:8400           0.0.0.0:0              LISTENING       1480
What could be happening?
Regards
Hi ​@EJIE,
In-order to resolve the 'No direct tunnel to CLIENTNAME' error, could you please check the below :
- Run a cvping test between the client & the CommServe to verify connectivity over port 8400 & 8403.
- Ensure that there are no firewall rules blocking traffic between the client and the server.
- For the de-coupled clients, go to client properties -> Network Configuration > Network Summary and check if there are any predefined routes confirmed from a Client Group to which client is a part (if added).
- Create a persistent tunnel between CommServe and CS using this - Setting Up a One-Way Direct Connection (Server to Client) Using a Predefined Network Topology
- Restart Client Service.
- Attempt to register the client from CommCell Console or Commandline - Registering Client Computers
Dheeraj
sbhatia
  • June 27, 2025
If your client is already installed but won’t register due to connectivity issues, the likely cause is firewall restrictions blocking CommServe’s access.
Quick fix: Create a pseudo client for that machine, and add one-way firewall rule allowing inbound TCP traffic from the CommServe to the client on port 8403 (or your configured tunnel port).
Steps:
  1. Open port 8403 on the client firewall for the CommServe’s IP.
  2. From the CommServe, run cvping -client <client_name> -port 8403 to verify connectivity.
  3. Once connectivity is confirmed, register the client via CommCell Console as usual.
