Update from 11.40 to 11.44 DBUpgrade Problem
  • Nov 13, 2026 7:54 AM UTC
  • 54 views
The Upgrade from 11.40 to 11.44 stop with DBUpgrade Problem:
The TableScript\App_CloudVendorRegion.sql faild, the File is avalible
11/12/26 14:05:21    ## DBUpgrade::removeDBUpgradeSteps ## Removed upgrade steps for this DataBase [CommServ].11/12/26 14:09:01    ## INIFileProcessor::executeSQLList ## INFO: [... inserting Table: App_CloudVendorRegion] [RecNum:1, LineNum:37, Spid:86] INFO: [Subquery returned more than 1 value. This is not permitted when the subquery follows =, !=, <, <= , >, >= or when the subquery is used as an expression.] [RecNum:1, State:21000, NativeErr:512, RowNum:1, Severity:16, LineNum:110, Spid:86] 11/12/26 14:09:01    ## CVSimpleDB::SQLINFO ## INFO: [... inserting Table: App_CloudVendorRegion] [RecNum:1, LineNum:37, Spid:86] 11/12/26 14:09:01    ## CVSimpleDB::SQLINFO ## INFO: [Subquery returned more than 1 value. This is not permitted when the subquery follows =, !=, <, <= , >, >= or when the subquery is used as an expression.] [RecNum:1, State:21000, NativeErr:512, RowNum:1, Severity:16, LineNum:110, Spid:86] 11/12/26 14:09:01    ## INIFileProcessor::executeSQLList ## Execution of file [C:\Program Files\Commvault\ContentStore\Base\DBUpgrade\CommServer\MainUpgrade/TableScript\App_CloudVendorRegion.sql] failed11/12/26 14:09:01    ## INIFileProcessor::processPhase ## Failed to process Phase [TableScript]. ReturnCode [2]11/12/26 14:09:01    ## DBUpgrade::executePhase ## Failed to process Phase [MainUpgrade] for Config File [C:\Program Files\Commvault\ContentStore\Base\DBUpgrade\CommServer\DBConfig.ini].11/12/26 14:09:01    ## DBUpgrade::runMainUpgrade ## Failed to execute Phase [MainUpgrade] for Database [CommServ].11/12/26 14:09:01    ## DBUpgrade::runUpgrade ## Main Upgrade failed for Database [CommServ].
  • Nov 13, 2026 8:34 AM UTC
HI ​@Thomas Trendel ,
The error is typically due to duplicate or inconsistent entries in related tables (such as ArchCopyAppRegionMap and App_CloudVendorZone), which cause the subquery to return more than one value.
The issue is resolved in latest MR. However, you may log support case to follow below resolution.
  1. Obtain the cleanup script CleanupAppCloudVendorRegionZoneTables.sqle and copy it to the CommServe machine.
  2. Run the script using the following command:
    qscript -f CleanupAppCloudVendorRegionZoneTables.sqle
    This will remove problematic entries from the ArchCopyAppRegionMap and App_CloudVendorZone tables.
  3. Resume the upgrade process. The upgrade should complete successfully.
Where can I download the script?
  • Nov 20, 2026 5:50 AM UTC
Hi ​@Thomas Trendel ,
Kindly log support case to review and assist further in running script to remove the entries.
We have fixet with this way:
$file = "C:\Program Files\Commvault\ContentStore\Base\DBUpgrade\CommServer\MainUpgrade\TableScript\App_CloudVendorRegion.sql"
Copy-Item $file "$file.bak" -Force
(Get-Content $file) -replace '\(SELECT id FROM App_CloudVendorRegion WHERE RegionCode', '(SELECT TOP 1 id FROM App_CloudVendorRegion WHERE RegionCode' | Set-Content $file
Select-String -Path $file -Pattern "SELECT TOP 1 id"
  • Nov 20, 2026 8:22 AM UTC
I see Select-String verifies that SELECT TOP 1 id was applied here. However, would recommend to reach support team to review this in detail and confirm.
