Best practices for HSX SAN mapping
  • Aug 21, 2024 2:29 PM UTC
  • 462 views
Forum|alt.badge.img+2
Hi
Mapped ESX Datastores via FC to a HSX cluster - reason behind is using SAN Transport mode.
Had to reboot the nodes as rescan-scsi-bus.sh didn’t work and couldn’t see the new devices.
However, now that I see the disks, backups are not running properly with “failed to read disk over SAN transport” error.
Any hints/tips on this? Couldn’t find much around as this is a storage related topic.
Appreciate the help around.
Ivan
Best answer by ivanalvarez
@Paul K it returns a complete list of “PhysicalDisk” and “Datastore Name”.
However it reports some errors about “Datastore ( XXXX ) has too many extents, check multipath settings and snapshots.” But I have already reviewed the entire SAN environment with the Storage guys and they can’t find any issues with the SAN zoning or the LUN mapping. Everything looks correct and the settings are as per Best Practices (Hitachi storage behind).
Commvault Support believes it’s related to a VMWare known issue “DiskLib error 4096062” once reviewed the VixDiskLib.log.
Hello @ivanalvarez
Can you use the following commands to confirm that the datastores can be seen by the HS nodes?
https://documentation.commvault.com/2024/expert/vmfssaninfo_tool.html
shell ./VMFSSanInfo datastore
I’m guessing the answer is no and with the rescan not working either we need to validate we can talk to the hosts on port 443 and 902.
This link has all the requirements and is a good one to check and confirm you have not missed anything simple:
https://documentation.commvault.com/2024/expert/san_transport_for_vmware.html
Kind regards
Albert Williams
  • Aug 26, 2024 8:38 AM UTC
Hi @Albert Williams
Thanks for the tip.
However, even though we see the datastores with the tool you mentioned, and both SAN zoning and LUN mapping look correct, we still have issues running jobs with SAN transport mode.
Errors are not helping really, as we still see the “Failed to read disk over SAN” and we believe at this point it could be VMWare related.
We have a case with CommVault Support and have uploaded some logs.
I will keep you posted.
Regards
Ivan
  • Aug 29, 2024 4:38 PM UTC
What does ./VMFSSanInfo datastores return?
  • Aug 30, 2024 7:53 AM UTC
