changing network topology from basic to bonded -hyperscale
  • July 4, 2023
  • 267 views
Forum|alt.badge.img+16
is it possible to change the network topology after creating the hyperscale x cluster /storage pool
Best answer by Emils
Hi @Ajal
Thanks for reaching out.
Yes it is possible to change the network topology, assuming all the back-end networking changes are ready.
Recommend first bringing the Commvault & Storage services down:
HSX:https://documentation.commvault.com/v11/expert/132928_stopping_and_starting_hyperscale_x_reference_architecture_cluster.html
HS1.5: https://documentation.commvault.com/v11/expert/98631_stopping_and_starting_all_nodes.html
Once done you can follow the steps on:
For DPN: https://documentation.commvault.com/11.23/expert/137350_configuring_network_bonding_for_data_protection_network.html
For SPN: https://documentation.commvault.com/11.23/expert/137351_configuring_network_bonding_for_storage_pool_network.html
Emils
  • July 6, 2023
Martin.Roende
Novice
Forum|alt.badge.img+2
  • May 2, 2025
I made the adjustment on a cluster yesterday. One thing that isn't mentioned in the documentation is that if the firewall is active on the nodes, the interfaces need to be updated in the rules accordingly.
