Commvault solution for 2 site data centre.
  • June 3, 2025
  • 12 replies
  • 226 views
Forum|alt.badge.img+5
Looking for advice on what model would suit a Greenfield deployment of Commvault to support a small < 20 TB deployment per site at 2 sites. Requirements are pretty simple! Back up some VM’s, Postgres databases, Active Directory with a mix of Windows and Linux OS. We prefer a Windows Commserve so I’m guessing a FREL is in the mix?  Must have cross site replication! So.. likely that would equate to 40 TB per site storage?
Management are keen on a self-contained appliance(s) solution with integrated storage or onboard storage is preferred BUT two small SANS are doable but not ideal. Unless I’m wrong two Hyperscale X appliances would NOT integrate to allow cross site replication?
What alternatives do we have? We would lean towards a server with onboard storage or DAS in preference to a SAN. We don’t need full redundancy per site just resiliency of backups with cross site copies.
What can you suggest? We currently maintain a single Commserve, multi site system with a SAN, Media Agents and VSA’s at each site. Maybe this model is best for new deployment? No, we can't just use the existing system, and it needs to be totally separate :-)
Erase4ndReuseMedia
Might be worth running it past your SE, but given the requirements, I would think a HyperScale X 2300 Appliance in each site would be more than sufficient.
  • June 3, 2025
Agree however how are offsite aux copies handled to the other site? Hyperscale X integrates with Cloud but we don’t have that and would only have another system at the other datacentre.
Erase4ndReuseMedia
Given the relatively small volume of data, I would just point a Secondary Copy to the alternate site HyperScale Storage Pool.
  • June 3, 2025
Ok so this storage pool is available to a totally separate instance of Hyperscale X? How is it presented to the other instance?  Sorry but I have zero knowledge of Hyperscale X.
Erase4ndReuseMedia
The appliances operate independently of each other.
I’m oversimplifying it, but at the Commvault level, a HyperScale appliance is really just a collection of MediaAgents and an associated Storage Pool. They’re not really treated any differently than a traditional deployment.
  • June 3, 2025
Ok so… AFAIK it’s not possible to share storage pools between separate Commvault deployments.  However, what if I could configure the Commserve instances in LiveSync which would allow central control over the combined Media Agent / VSA components of the entire system?  it would fit the bill perfectly.  Now is that possible?
Erase4ndReuseMedia
You can have multiple HyperScale appliances within a single CommCell environment. For your Site A Storage Policies, you configure a Secondary Copy to your Site B Storage Pool, and vice versa. Just like any other CommCell environment.
What region are you in?
  • June 4, 2025
Thanks for reply but I’m missing something! From the following link Multi-CommCell Environments
A CommCell environment is the logical grouping of all software components that protect, move, store, and manage data and information. A CommCell environment contains one CommServe host, one or more MediaAgents, and one or more clients.
Given a Hyperscale X appliance contains a CommServe and Media Agents it could be considered a Commcell environment. It is possible to manage multiple Commcell environments using Universal and Global Command centre with a Primary and other Service Commcells but I don’t know if it's possible to share resources between them. From previous experience no, but in this case would like to be proven wrong :-) I’m in Asia Pac and think we will explore this with sales.
  • June 4, 2025
Or were you possibly talking about GRC??
Erase4ndReuseMedia
The HyperScale appliances can contain the CommServe - but they don’t have, you can connect an appliance to an existing CommCell.
For your use case:
Site A HyperScale could be deployed with the CommServe on the appliance.
Site B HyperScale could be deployed, and joined to the Site A CommServe.
Site B HyperScale could then host the Standby CommServe (LiveSync).
Based on your location, I recommend you reach to Fazeel. He is really knowledgeable.
@Faz Maybe?
  • June 4, 2025
Righto! Now I’m seeing the picture! So, it is possible to run two hyperscale appliances in LiveSync which would certainly fit our requirements! Thanks for the efforts!
  • June 4, 2025
Do you have a third, possibly a Corp HQ, datacenter with decent bandwidth and access to both of these remote sites?
Even better, is there an existing (brownfield) infrastructure in an existing HQ DC that you could leverage?
Unless there is a justifiable business driver to put the Commserve “local”, there is no technical requirement to have the Commserve hosted onsite at either of your “new” sites.
Also, if you don’t need high resiliency at either site, I’d be tempted to consider a conventional (non-Hyperscale) device at each site. A COTS Intel based 2U server can hold several hundred TB of internal disk.
If you prefer, you can preinstall with Windows MA config and cross-replicate between the two (using a 3rd site Commcell)
Installation and management complexity is reduced versus Hyperscale, if you’re not on site, and are remotely directing local hands/eyes.
FREL is required for file level recovery if using Windows MAs.
One benefit of Hyperscale (or conventional MA running Linux) is that these MA nodes intrinsically provide the service otherwise delivered by FRELs, eliminating the extra resource to manage.
