Create Storage Pool Failed[Reason:There is an issue with HyperScale X storage configuration.
  • Sep 24, 2026 2:31 PM UTC
  • 38 views
Our customer is using Metalic. If we open the metalic interface and go to Hyperscale storage we are seeing an error: Is cannot be deleted. See failere below, according Arly there is an script to delete this error message.
 Step 1: In an elevated Command Prompt on the CommServe, run: Qscript.exe f ScriptSetStoragePoolStatus.sqle -i 3 after placing the script in the Base directory.
Source: Provided action item for HyperScale X storage pool status issue.
Where can i find this script?
Bronco
  • Sep 25, 2026 2:00 AM UTC
While script looks easy but to make it work we need few other things needs to check from database end. So, it would be better to have support case opened to go though it.
Siddharth Gandhi
  • Sep 25, 2026 5:13 AM UTC
I will do. Thanks.
