Create Storage Pool Failed[Reason:There is an issue with HyperScale X storage configuration.
  • September 24, 2026
  • 12 views
Our customer is using Metalic. If we open the metalic interface and go to Hyperscale storage we are seeing an error: Is cannot be deleted. See failere below, according Arly there is an script to delete this error message.
 Step 1: In an elevated Command Prompt on the CommServe, run: Qscript.exe f ScriptSetStoragePoolStatus.sqle -i 3 after placing the script in the Base directory.
Source: Provided action item for HyperScale X storage pool status issue.
Where can i find this script?
Bronco
  • September 25, 2026
While script looks easy but to make it work we need few other things needs to check from database end. So, it would be better to have support case opened to go though it.
Siddharth Gandhi
I will do. Thanks.
