Create Storage Pool Failed[Reason:There is an issue with HyperScale X storage configuration.
  • Sep 24, 2026 2:31 PM UTC
  • 42 views
Our customer is using Metalic. If we open the metalic interface and go to Hyperscale storage we are seeing an error: Is cannot be deleted. See failere below, according Arly there is an script to delete this error message.
 Step 1: In an elevated Command Prompt on the CommServe, run: Qscript.exe f ScriptSetStoragePoolStatus.sqle -i 3 after placing the script in the Base directory.
Source: Provided action item for HyperScale X storage pool status issue.
Where can i find this script?
Bronco
  • Sep 25, 2026 2:00 AM UTC
While script looks easy but to make it work we need few other things needs to check from database end. So, it would be better to have support case opened to go though it.
Siddharth Gandhi
  • Sep 25, 2026 5:13 AM UTC
I will do. Thanks.
  • Nov 18, 2026 5:56 PM UTC
​@Cyber_backup ,
Since this is a Metallic-managed environment, the CommServe and its backend/database are managed by Commvault. For this reason, I would recommend opening a Commvault Support case rather than obtaining and running ScriptSetStoragePoolStatus.sqle manually as you wont be able to run them.
This QScript involves a database-level correction, so Support should first validate the actual HyperScale X storage pool state and corresponding database entries before determining whether the script is appropriate.
So, in this case, the appropriate path would be to raise a Support case and let Commvault validate and correct the backend/storage-pool state as required.
If you have already opened a Support case and the issue has been rectified, please let us know the outcome.
