HSX - Data Aging vs DDB Space Reclamation use case
  • January 13, 2026
  • 200 views
PedroRocha
Apprentice
Hello!
Considering an HSX environment.
How does the data aging process compare to the DDB space reclamation?
Sometime I only see space being reclaimed after a DDB space reclamation job.
Pedro
Bronco
  • January 13, 2026
Hello!
Pedro
In an HSX environment, Data Ageing and DDB Space Reclamation are complementary but separate processes. Each serves a different purpose in managing and reclaiming storage space, particularly in deduplicated storage pools.
==> Data Aging
Purpose
Data aging is a logical cleanup process that identifies backup jobs which have exceeded their configured retention period.
How it works
- Commvault evaluates retention rules and marks eligible jobs as aged.
- A pruning phase then removes job metadata and logical references to those backups.
Impact on disk space
- In deduplicated storage, data aging does not immediately free disk space.
- Deduplicated blocks may still be shared by other backups, so the physical data remains intact until all references are removed.
Outcome
- Aged jobs are no longer recoverable.
- Disk usage may remain unchanged immediately after data aging, which is expected behavior in deduplication environments.
==> DDB Space Reclamation
Purpose
DDB space reclamation is the physical cleanup process that actually frees disk space.
How it works
- The system scans deduplication containers for unused or unreferenced data blocks.
- Chunks with a high percentage of reclaimable space are rewritten or removed, depending on the reclamation level.
- This process physically deletes unreferenced data blocks.
- Disk space becomes available for new backups only after successful space reclamation.
Outcome
- A measurable reduction in used disk capacity.
- This is the step where customers typically observe actual space recovery.
==> Why Disk Space Is Reclaimed Only After DDB Space Reclamation
- Data aging removes logical references but does not delete shared deduplicated blocks.
- DDB space reclamation consolidates and removes blocks that are no longer referenced by any job.
- In HSX, reclamation may run automatically when free space thresholds are reached, or it can be initiated manually when immediate space recovery is required.
PedroRocha
Apprentice
  • January 13, 2026
Hello!
Pedro
==> Data Aging
Purpose
How it works
Outcome
Purpose
How it works
Outcome
Thank you very much for this detailed answer!
One last question: I understand that in a HSX environment, data aging jobs will never free up space (physical). Is that correct? There must be always a DDB space reclamation job to complement the logical process made by the data aging job?
regards,
Pedro
Bronco
  • January 28, 2026
Hello!
Pedro
==> Data Aging
Purpose
How it works
Outcome
Purpose
How it works
Outcome
regards,
Pedro
Hello Pedro,
  • Data aging alone does not guarantee physical space is freed for deduplicated data.
  • DDB space reclamation is needed to physically reclaim space after data aging for deduplicated storage.
  • On some modern storage (with micro pruning and sparse files), space may be reclaimed automatically.
Siddharth Gandhi
