Hyperscale X on ESXi for Lab
  • December 7, 2025
  • 7 replies
  • 191 views
Dear All,
I am trying to build a HyperScale X Lab in our office. I am using sp40_13_hsx_prod_dvd_09152025_061956.iso it is failing on Creating Building Storage Configuration. Please assist.
Bronco
  • December 7, 2025
Dear All,
Hello ​@Deep,
Please raise a case with support we are happy to assist you further.
Siddharth Gandhi
Emils
  • December 8, 2025
Hi ​@Deep
I've noticed you've only got one drive which is less than 240GB for the metadrive.
Can you re-try with having 2x drives for your Meta Drives (2x120 will suffice)? The rest looks fine to proceed for the purpose of a testing lab.
Thank you
Hi ​@Deep ,
You can open a case with support and provide the screenshot of /var/log/hyperscale.log and /var/log/bmr.log from the node where the storage initialization failed to assist you further
Sridhar Sundar Rajan
  • December 8, 2025
Hi ​@Emils
Now I am able to complete the installation. But it is stuck at following screen
  • December 8, 2025
Hi ​@Deep ,
Hi ​@Sridhar Sundar Rajan
I am running this environment on ESXi 8.x Platform. as this is for LAB environment I dont know if support Team will take incident and will support me
Hi ​@Deep
Seems like the installation is complete. Press Alt+F2 and see whether you are getting the login prompt.
Hi ​@Deep
Were you able to achieve the lab nodes for which this thread has been opened?
