HyperScale X override Commvault tunnel port
  • Jul 23, 2024 12:53 PM UTC
  • 114 views
Hi all,
My customer use a specific commvault tunnel port instead of default one. We have installed fresh HSX reference architecture in 11.32.
We have noticed that by disabling firewall on HSX node, commvault firewall is working, rather than when it’s enabled, probably due to default rule allowing the default commvault tunnel port (8403)
It’s referred on this link : https://documentation.commvault.com/2023e/essential/firewall_port_requirements_for_hyperscale_x_reference_architecture.html
Is there any way to allow a rule in firewalld to override default commvault firewall tunnel port (8403) to a specific port currently used in my customer commvault environment ?
Many Thanks
Vincent
Best answer by R Anwar
Hi @Vincent633
With SP32 firewall uses a default config. In case you want to manually update, changes need to be made to /usr/lib/firewalld/services/commvault.xml.
We are coming up with option to have additional ports in newer SP release.
R Anwar
  • Jul 25, 2024 6:48 AM UTC
Hi @Vincent633
  • Jul 25, 2024 8:07 AM UTC
Many thanks for your reply.
We will configure back to default port.
regards,
