Issue at implementing airgap on HSX cluster
  • Nov 3, 2024 6:13 AM UTC
  • 108 views
Forum|alt.badge.img+5
Dear Community,
I try to configure airgap interval on HSX cluster from 7AM to 4AM next day to allow aux copy for 3 hours only , when I run command “./cvsds -c 7:00 4:00” I get “Failed to get storage services status”.
Kindly need your support.
Could you temporarily try a different time range? - I’m wondering if it is having issues parsing the range you put
Looking at the example in the docs:
# ./CVSDS -C 18:20 19:20
See if this works, and if so, this seems like a support case.
Forum|alt.badge.img+8
  • Nov 14, 2024 5:21 PM UTC
You say you want “7am to 4am” to allow for 3 hours only.
It sounds like you meant to configure it from 4am to 7am as that is a 3 hour window.
./cvsds -c 4:00 7:00
