Migrating Hyperscale X to an existing commserve
  • Jan 29, 2024 10:44 AM UTC
  • 122 views
I want to know if there is a procedure when we want to migrate an existing hyperscale X to an existing commserve?
Regards
R Anwar
  • Jan 29, 2024 1:13 PM UTC
Hi @nhaing
If you are looking to use HSX on another CS, then you need to clean the nodes i.e. delete/age data, delete StoragePool and MA.
Once done, re-image the nodes and register on new CS.
  • Jan 31, 2024 12:51 PM UTC
Hello @R Anwar,
thanks for your reply, i want to know what you mean exactly to “re-image the nodes and register on new CS. “.
Is there any documentation for the case?
Regards
