Plan for a HyperScale replacement / upgrade
  • Jan 9, 2026 5:54 PM UTC
  • 185 views
Ken_H
Explorer
Forum|alt.badge.img+18
Hello everyone,
I’m currently storing backups on a HyperScale 1.5 cluster that was purchased back in 2018. I’ve just taken delivery of three HPE servers to act as a HyperScale X cluster to replace my aging HyperScale 1.5 media agent.
Does anyone know of a detailed list of steps / project plan / checklist that can be used for such an undertaking?
I see the high level steps as:
  1. Rack the servers
  2. Install the HyperScale OS
  3. Connect the new cluster to Commvault
  4. Update backups to use the new storage
  5. Migrate backups from the old HS 1.5 to the new HS X storage
  6. Disconnect the empty HS 1.5 media agent from Commvault
  7. Power off the HS 1.5 servers, remove them from the rack, and dispose of them.
The reason I’m looking for detailed steps is that I’m sure there are items I’m not aware of that need consideration. Some examples of this are 1) enabling encryption of backups and 2) enabling ransomware protection. There’s probably other things I need to consider that I’m not aware of and I don’t want to get to the end of the process only to realize I missed a configuration from an earlier step.
I see this documentation: Setting Up the Installation Media for HyperScale X
I’m grateful for any suggestions,
Ken
R Anwar
  • Jan 12, 2026 6:12 AM UTC
Hi ​@Ken_H
Kindly check the doc https://documentation.commvault.com/2024e/software/getting_started_with_hyperscale_migration.html
Let us know in case of any queries.
Ken_H
Explorer
  • Jun 30, 2026 5:05 PM UTC
Thanks for the feedback. The installation and configuration of the new hardware and the installation and configuration of the Hyperscale X OS was simply beyond what we were capable of doing on our own so we engaged Commvault Professional Services. Even with an expert on the line running the installation, it took two days to get the initial HSX installation completed. I don’t really understand why but it took more than half a day to get the ethernet ports properly configured. This appears to be something that will never be a client-installed option.
I would encourage anyone planning to implement a new Hyperscale media agent to budget for five days of professional Services support. It will be money well spent. We have used three of our five days and there continues to be several issues with the new storage. Our support analyst appears to know what he’s doing so I’m hopeful everything will be resolved before our engagement hours run out.
