Using the hyperscale X as access node for CIFS backups
  • Nov 25, 2025 8:30 AM UTC
  • 199 views
I’m trying to back up Netapp CIFS share with the Hyperscale as access node
The hyperScale have  11.36 with ISO 3.2506
I cant choose the HSX as access node while browsing the content and the back up failed with
“Failed to mount file share volume“
the HSX has cifs-utils installed and samba-client installed
AM I missing someting that is required for CIFS backup with Hyperscale X as access node?
Bronco
  • Nov 25, 2025 8:56 AM UTC
Hello LiorRN,
HyperScale X nodes cannot be used as NAS Access Nodes because the HSX operating image does not include the Commvault NAS package required for CIFS/NFS traversal, and therefore CIFS shares cannot be mounted or enumerated on HSX
1. HyperScale X nodes cannot be used as NAS (CIFS/NFS) Access Nodes. HSX OS image does not include the NAS package, and therefore cannot perform SMB/CIFS scanning or mounting required for NetApp CIFS backups.
2. Even if "cifs-utils" and "samba-client" are installed, HSX still lacks the Commvault NAS components. The HSX ISO excludes:
==>  NAS Package
==>  NAS Helper Modules
==>  FUSE-based NAS scanning libraries
==>  Required Python modules for NAS traversal
3. Therefore HSX nodes will not selectable Access Nodes for NetApp CIFS shares. This is expected and documented Commvault behavior.
4. CIFS backups require a supported Access Node with NAS package installed.
Official supported types:
==>  Windows File System Agent (recommended)
==>  Linux Access Node with NAS Package (Non-HSX Linux only)
5. As a solution, deploy a separate Windows or Linux Access Node and assign it to the NetApp CIFS client.
Siddharth Gandhi
  • Nov 27, 2025 10:09 AM UTC
thanks
  • Nov 17, 2026 1:46 PM UTC
Thank you for the clarification regarding CIFS/NFS backups.
I would like to clarify whether the same limitation applies to NDMP backups.
Our environment is running Commvault 11.44 with a 3-node HyperScale/Grid cluster, and we need to back up NetApp ONTAP volumes using NDMP directly to the HyperScale Storage Pool.
Since NDMP uses the NDMP Remote Server functionality included with the MediaAgent and does not require CIFS/NFS mounting or file system traversal, can HyperScale/Grid nodes act as NDMP MediaAgents without deploying a separate proxy server?
Or is a dedicated Windows/Linux MediaAgent required for NDMP operations as well?
I'm specifically looking for confirmation of the officially supported architecture for NDMP, rather than CIFS/NFS network share backups.
