SaaS Specialist PLUS for MSPs - ONE Subject "under maintenance"
  • July 18, 2025
  • 8 replies
  • 116 views
Hi There
Currently doing the “SaaS Specialist PLUS for MSPs” learning path, and I’ve finished all but one subject.
That is “SaaS Specialist - Active Directory and Azure Active Directory - 2022”.
“You cannot access the course because it is under maintenance”
It’s been like this all week, and its the only subject I have left on it.
Is there anymore information or update on when this will be available????
Best answer by Sougato Roy
Hi There
Hi Thomas,
Thanks for sharing the info about this course. Let me check with the Enablement team and I'll get back to you once I hear from them.
Thank you,
Roy
Okay great thanks, will wait for update!
Hi ​@Thomas Rutherford,
Thank you for being patient with us. The team has informed me that the issue has been resolved, and your learning plan has been updated with the new one.
I will keep this conversation open while you confirm the changes on your end. Please let me know if you're still experiencing any problems.
Best regards,
Roy
Sougato Roy
  • July 18, 2025
Hi There
Hi Thomas,
Thank you,
Roy
Lukas3D
Explorer
Forum|alt.badge.img+13
  • July 18, 2025
The version from 2022 will be outdated, since Commvault changed the AD backup agent in 2024.
That’s great and all but how can I finish this plan with it locked and no status update on it?
Hi There
Hi Thomas,
Thank you,
Roy
I’m sure ​@Sougato Roy is chasing this down, but we have a new AD module just built in the last month or so - so that should be the replacement for this older one. We’ll get this fixed up - thanks for letting us know!
Sougato Roy
  • July 22, 2025
Hi There
Hi Thomas,
Thank you,
Roy
Best regards,
Roy
Can confirm it’s all working now! Thanks for the prompt responses everyone!
Sougato Roy
  • July 23, 2025
Thanks for confirming and we're trying to improve even more in the future. 😀
