Air-Gap Protect: On-Prem to Commvault Air-Gap Protect (formerly Metallic?) - Performance
  • March 25, 2025
  • 167 views
DaysAndCycles
Apprentice
Commvault 11.32
1PiB of back-end data (compressed/deduped/stored size)
Aux copying data from secondary copy of backup data.
Four physical media agents on-prem
Four virtual media agents in Azure
5Gbps ExpressRoute circuit from on-prem to Azure
There is about 20ms of latency between the physical on-prem MAs and the Azure virtual MAs
We have deduplication/DASH copy enabled.  We saw atrocious performance, from the start.
Seeing that 20ms of latency would certainly impact DDB look-ups on the virtual MAs, we turned on “Source Side Disk Cache” in the storage policy copy (we kept the default 8192MB cache size).
It’s running a little bit faster, but still pretty sluggish.
Would we expect to see a further boost in performance by expanding the “Source Side Disk Cache” from 8192MB to ~128000MB?   That should further reduce the incidence of remote DDB look-ups on the Azure virtual MAs, right?
Are there any other best practices for speeding up the transmissing of Commvault aux copies from an on-prem site to Azure virtual MAs via ExpressRoute, and on to Commvault Air-Gap Protect?
Thanks in advance!
DaysAndCycles
Apprentice
Update: The Source Side Disk Cache is apparently hiding in the “Job Results” directory on each source Media Agent.
We have a spare NVMe SSD disk in each Media Agent, so we’ll move the “Job Results” directory to the new disk and change the cache size to 128GiB.
DaysAndCycles
Apprentice
Update on this:  On the recommendation of our Commvault TAM, we added the Media Agent “additional setting” ‘SignaturePerBatch’ to each of our media agents.  We modified the DDB signatures per batch from the default of ‘1’ to the max of ‘32’.  Now 32 signatures are checked for each trip to Azure (instead of just one).   Seems to run much, much faster.
