AirGap capacity
  • Sep 25, 2024 11:33 AM UTC
  • 256 views
If I understand correctly with a license of 20TB AirGap customer can send to Azure up to 20TB of local data. With AirGap the space occupied in Azure will be 2x or more (40+TB). There is no extra cost for the customer for this 2x+ capacity, it is included in the Commvault license they have correct?
Thanks a lot
Panos
Best answer by Scott Moseman
20TB of AGP will give a customer 20TB of AGP.
I assume there’s confusion about enabling immutability.  If a customer uses third-party cloud storage, there is 2-3x space consumption when enabling immutability.
This 2-3x penalty does not apply when using AGP.
Scott
Scott Moseman
Forum|alt.badge.img+23
Scott
  • Sep 25, 2024 1:43 PM UTC
Thank you Scott!
