Auxiliary Copy Speed?
  • May 25, 2022
  • 198 views
Steve-O
Novice
Forum|alt.badge.img+2
My Metallic Auxiliary Copy looks to be moving between 20 and 40 Mbps.
My fiber internet is 200/200Mbps.
Where do I start looking to troubleshoot/adjust the Auxiliary Copy speed?
Note: I am in a demo, so if the VM or File demo has a cloud copy speed maximum that would be good to know.
@Steve-O as Metallic is based on Commvault Complete you could look into https://documentation.commvault.com/11.26/expert/8665_recommended_antivirus_exclusions_for_windows.html and https://documentation.commvault.com/11.26/expert/8670_recommended_antivirus_exclusions_for_unix_and_macintosh.html
If possible I would first see if you can turn off anti-malware/anti-virus on both source and destination to see if it actually makes a difference.
Steve-O
Novice
  • May 25, 2022
I think it may be my anti-malware client (Palo Alto Cortex).
My firewall is showing more traffic to their “wildfire” service while the aux copies run.
Is there a list of anti-malware/anti-virus exclusions for Metallic gateways and other services (VM, VMhost, File Server, SQL) ?
I can only find a small reference to endpoint backup agents. Setup Considerations for Endpoint (metallic.io)
Onno van den Berg
Forum|alt.badge.img+24
