Commvault SAAS Azure Market place
  • March 4, 2026
  • 149 views
JosserandM
Apprentice
Guys,
Source : https://marketplace.microsoft.com/en-us/search/products?search=commvault&page=1
I am not able to find a proper CV Access Node / Gateway for Metallic SAAS in the Market place… any idea why ?
Jennifer Kelley
Forum|alt.badge.img+20
Hi ​@JosserandM - I’ve raised this with our Marketplaces team and will provide an update when I know more. Thanks!
Jennifer Kelley
Hi ​@JosserandM our team has updated some settings and is republishing. There may be a lag, but you should see them later today. If you still don’t see them by tomorrow, let us know. Thanks for the note!
JosserandM
Apprentice
  • March 5, 2026
Hello team, there is only the access node with standard registration process, we need to get one who is able to use Custom Data to add the AuthCode from our SaaS plateform to authenticate it seff, actually we need to log in (as the ancien fashion) to launch a setup file. please ask the market place team if they plan to have a true Image using custom data ? Thx !
Jennifer Kelley
Hey ​@JosserandM - I don’t think I fully understand the ask. Are you saying you can’t use an authcode for registration, or you would prefer not to and instead use username/password?
If you could clarify the situation a bit I’ll see how we might be able to pass that on or help.
JosserandM
Apprentice
  • March 6, 2026
Hello, now i m speaking about deploying Access node for SAAS using IaC or Azure native capacity avoiding any login in the the VM itself.
Azure is proposing “Custom Data” to allow action in the VM to configure properly the register to the SaaS Platform.
Why don’t use it ? see capture, many vendors are using this king of tools to deploy AMI properly
