Create Metallic tenant
  • April 7, 2022
  • 130 views
Forum|alt.badge.img+13
we have buyed metallic licenses and i have the license certificate.
What do i have to do now to create a tenant?
Regards
Dennis
Best answer by Dennis
No.
I tryed to login with my e-Mail to https://login.metallic.io/#/ and that works.
I think Commvault had created the account for me.
  • April 7, 2022
Login now works…..
Onno van den Berg
Forum|alt.badge.img+24
So you just had to be patient ???
  • April 7, 2022
No.
Steve-O
Novice
  • April 20, 2022
I had the same.  The backend took 2 days to sync before I could log in.
