Failed to determine volume and path info error
  • Jul 10, 2025 9:32 AM UTC
  • 151 views
Has anyone seen this error when using intellisnap to back vm’s up using NetApp
[Failed to determine volume and path info. Error[0xEDDD0001:
{CvNetAppArrayOps::determineVolumeAndPath(380)/Int.1.0x1-Connection failed. Error[]}]]
We started seeing it in June and didn’t make any changes on our storage/vmware/or Metallic side. It was not due to an upgrade either
Thank you,
  • Jul 10, 2025 10:33 PM UTC
Hi Mallic,
This isn’t an error we’ve seen often. In the past this has been seen when trying mount a snap. The solution I found was to reference the hostname for mounting snaps using the additional setting below on the media agent that handles the mount requests.
https://documentation.commvault.com/additionalsetting/arraymanagementname-dataiporhostnameformount.html
Being SaaS this may not be something you can achieve depending on your infrastructure. If that’s the case I would recommend raising a support incident so our SaaS team can address it for you.
