failed to discover content for Onedrive / exchange / Sharepoint on metallic
  • Apr 16, 2024 8:18 AM UTC
  • 212 views
maxime.mimran
Apprentice
When I try to add content to the various O365 applications on metallic, I get a discover task launched but it doesn't execute.
I click on refresh cache, it goes to "in progress" then if I refresh it goes back to "not started". I get the same error for all applications.
This isn't the first time I've configured apps on metallic, and it worked fine a few weeks ago.*
has anyone ever had this problem?
Kind regards Max
Forum|alt.badge.img+5
  • Apr 16, 2024 11:49 AM UTC
Hi Maxime
Sorry to hear you are having issues with the discovery.
Just wondering how long you allowed it to run for, and did anything eventually show up.
If there is still no data please check your Apps are authorised from the Configuration screen.  You can run the authorize app to be sure.
If that fails I would delete it and create a new one just in case.
If there is still an issue please reach out to support to assist.
Regards
Andy
