Index restore Commvault Cloud
  • Mar 27, 2025 11:08 AM UTC
  • 85 views
Forum|alt.badge.img+2
Hi
Today I noticed a job running which I presume was initiated by CommCell which I have no accesses too
Index Restore Commserve Management.  If anyone knows what this entails I would be much obliged.
We are running Metallic (Commvault Cloud )
Regards
Tony
Best answer by Lukas3D
Hi Tony,
You have both data (backups stored on disk/cloud) and metadata (indexes). Metadata for recent backups is retained for ~two weeks. If you need to restore/browse for something older, the system may need to retrieve metadata stored alongside those older backups.
You can find more here Indexing Version 2
Lukas3D
Explorer
Forum|alt.badge.img+13
  • Mar 27, 2025 11:56 AM UTC
Hi Tony,
  • Mar 27, 2025 12:08 PM UTC
Thanks for that Lukas3D
