Metallic - Cross-Hypervisor restore from VMware to Azure
  • July 5, 2022
  • 178 views
I have to perform VM machine restore from VMware Hypervisor to Azure resource manager. I was gone through below documentation and need some clarification on this.
https://docs.metallic.io/metallic/137982_azure_considerations.html
Considerations for converting VMware to Azure VM. Below tasks must be done before starting a source VM backup.
Install Hyper-V drivers (hv_vmbus hv_netvsc hv_storvsc) on the source VM - As it’s mentioned Hyper-V drivers, So, will this only needs to be installed if source is Hyper-V VM or is it applicable for VMware VM as well?
Run the following command to modify the boot image: (sudo dracut -f -v -N) - what is the actual impact of modifying boot image and will this cause anything for source VM?
Considering the source VM OS is Red-Hat Linux - Is above two tasks are enough to start with source VM Backup or is there any additional settings needs to be changed/taken care before start with source VM Backup.
Best answer by Mohit Kshirsagar
Hi @Ramkumar
Yes. Those drivers are needed when converting to azure. Azure platform runs on Hyper-V and these drivers are equivalent to VMTools in VMware
Mohit Kshirsagar
Hi @Ramkumar
