Hi guys,
Thank you very much for your responses.
I think I can do without the risk of potential brain damage. 😉
To clarify about the ‘multiple boot images on a single usb drive’, an IBM i client’s SAVSYS creates multiple ISO image files where only the first image file contains the boot software, or what we call Licensed Internal Code (‘LIC’). The remainder of the up to a total of nine image files contain the Operating System software, security data (user profiles etc), configuration objects like comms lines and display device descriptions, the base CommVault product libraries, other IBM libraries for various IBM i Licensed Program Products (‘LPPs’), and various other system libraries and files. all this would be restored to get to the point where the IBM i system can communicate with the CommVault server and begin the restore of all user data.
In theory all the ISO image files should be able to be loaded onto a single USB drive, then be able to boot from the LIC image, followed by a restore of everything else as described above. This would be similar to how an OS upgrade is implemented where the OS upgrade LIC, OS and LPPs image files are all stored in what we call an Image Catalog that is then mounted on a virtual optical device. The Image Catalog and virtual optical device are both configured on the IBM i system. We then IPL (reboot) the system telling it to restart from the virtual optical device. Hey presto.
Of course initiating a full system recovery is not the same as a OS upgrade where we specify ahead of time that the system is to execute a normal IPL (restart) from the virtual optical device and press the Enter button.
For a full system recovery the system has crashed with an unrecoverable fault. But in that situation we can specify that the system is to restart from an Alternate IPL Device. This is done via what is called an Hardware Management Console (HMC) that is a stand-alone server for the management of the physical [Power9] server and the IBM i systems (what you may know as Virtual Machines and what we call Logical Partitions in IBM i land) hosted on the server.
In saying this, one thing we will need to check is if the format of the image files created on CommVault are the same as the format of the OS upgrade image files we download from IBM, Something we can test on our sandbox IBM i system.
Re the IPMI option, interesting. I have been playing with IPMI provided by the HMCs we have that we use to manage our two Power9 servers and IBM i LPARs. These HMCs are actually IBM Power8 servers. And just last week I was considering whether the Power9 servers also have the IPMI capability. Something to check out.
Hey, it is good to talk this through with you. We may be onto something here...
Thanks guys,
Jozsef
