1-Touch restore problem Linux
  • Feb 22, 2024 12:02 AM UTC
  • 117 views
Hello all,
While trying to start 1-Touch restore from FS backup of RedHat 8.8 we are having this issue after first stage of restore:
Does anyone know what might cause this problem?
Best answer by Alex Deaconu
Hi Grzegorz,
The Stage Two KExec init will get killed when the system is running low on memory. Assuming this is a Virtual Machine, try to allocate at least 8 GB of memory to the 1-Touch Client. You can decrease the RAM after the restore is complete.
I saw this happen in the wild often, in all the cases that was the issue. Let us know if that fixes it for you too, or if it might be something else.
Alex Deaconu
  • Feb 22, 2024 2:45 PM UTC
Hi Grzegorz,
  • Feb 28, 2024 9:56 AM UTC
Thanks for Your tip! We will test it out, and I will post a result if someone in future will face this issue!
  • May 9, 2024 1:18 PM UTC
Hi all!
Once again thanks you for all tips!
Problem solved!
If someone faces the same problem - increasing ram for VM while being restored helped!
