a guide for configuring archiving
i have the comvault 11.32.73, the tape drive eternus lt20 s2. i need a guide for configuring. i have to archive my backups backuped: virtual machines, sharepoint data, data of end users. on host, where is connected my eternus lt20 s2 i installed media agent. what i do?
Mohamed Ramadan
Explorer
hello ​@gogi100
Are you asking about long-term backup?
I’ve checked, and your tape storage is supported.
It’s simple once you connect the tape storage to the MA, just follow the article below:
https://documentation.commvault.com/2024/essential/configuring_tape_storage.html
if you need more info feel free to ask
Mohamed Ramadan
Data Protection Specialist
  • February 10, 2025
one more question. my company bought a tape drive fujitsu eternus lt20 s2 and 8 cartriges model quantum ultrium 8 data cartridges. however, we did not get labels with the cartriges. will the cartridges work in the device?
Mohamed Ramadan
Explorer
hello ​@gogi100
feel free to ask anything you want!
If your tape media doesn’t have a barcode reader, you can configure it as a Blind Library. In this setup, the system initializes the tapes with an On-Media Label (OML), which is a unique ID assigned when the tapes are first detected.
https://documentation.commvault.com/v11/expert/blind_libraries_overview.html
Mohamed Ramadan
  • February 28, 2025
in my commcell browser application i added my tapedrive in storage resources, libraries and i have a tape library FUJITSU ETERNUS LT S2 6. In the storage pool exists FUJITSU ETERNUS LT S2 6. In slots i have 8 tapes. what is the next step? I want the backups made in the two libraries QNAP and RezervnaKopija to be archived on my tapes. Do I need a policy? also, my server where the eternus lt20 s2 is connected via sas has two network adapters and media agent, one is in the network 192.168.99.0/24 where commvault is located, and the other is in the network where qnap is 192.168.170.0/24 where backups are made
