Adding expansion modules for tape library (HPE MSL 6480)
  • May 8, 2023
  • 208 views
We will be adding 2 more expansion modules (160 slots and 16 LTO8 drives in total) for out tape library. I haven’t done this task before, so I wonder do I need to stop the Commvault service on all of my Media agents when I do the detect the new expansion modules with the Expert Storage Configuration?
Thank you.
That is not needed. Just put the library in maintenance mode that should be sufficient!
Onno van den Berg
Forum|alt.badge.img+24
  • May 9, 2023
Hi @Onno van den Berg Thank you so much for the response. Another question, we already have 2 drive pools for the tape library, so I don’t need to select “Automatically Create DDS Drivepools” when doing the Detect library right?
Forum|alt.badge.img+9
  • October 17, 2023
Hi ,
Yes, that is correct we do not need the option “ Automatically create DDS Drivepools” selected.
