adding oracle OCI PCA
  • June 27, 2024
  • 91 views
Forum|alt.badge.img+16
Dear Community ,
  • Install the Virtual Server Agent (VSA) on at least one Oracle Cloud Infrastructure instance. You can install the VSA on other machines to create additional VSA proxies. At least one VSA proxy is needed.
what is access needed from proxy, if there are private and public connection, do we need access to manager and vm subnets ?
  • Identify the Oracle Cloud Identifier (OCID) for the tenant and for the admin user for the hypervisor.
    can anyone help how can we do this
  • Add required permissions for the OCID tenant and user.any link to refer creating user with required permssion
  • Create a folder (called base_folder\certificates\external\ for Windows proxies, or called base_folder/certificates/external/ folder for Linux proxies) on the VSA proxy instance. Obtain the private key, password, and fingerprint for the private key, and then copy the private key to the newly created folder.
    For more information, see the following pages in Oracle Cloud Infrastructure documentation:
Hello @Ajal
Thanks for the question and details. The link in your question leads to a list of permissions required:
https://documentation.commvault.com/2024e/essential/permissions_for_oracle_cloud_infrastructure.html
Can you advise what questions you still have after going over all of this?
Kind regards
Albert Williams
Hello @Ajal
Kind regards
Albert Williams
