Anyone using the additional setting "DontRenameVMClients" setting? When is it needed?
  • January 17, 2023
  • 59 views
No special characters
Explorer
I noticed a VM names mismatch in the JavaUI and WebUI.
VMs in the JavaUI sometimes have a different name in the WebUI.
Commvault support says it is probably because of the additional setting on the CS: “https://documentation.commvault.com/additionalsetting/details?name=%22DontRenameVMClients%22&id=7490”
Unfortunately, it is not documented on our end why this is set on this particular CS.
I would like to remove it, but would like to know when/why this setting should be used.
Anyone?
Thanks.
Best answer by Orazan
Good afternoon.  I have checked with my Client team resources and while this setting is known, it is not one that is commonly used.  I would think in most situations you would want the client names updated to reflect name changes in VMWare.
Forum|alt.badge.img+18
  • January 17, 2023
