Assign data classification Plan for Threat Scan
  • May 3, 2024
  • 159 views
When trying to assign any data classification plan with our clients it shows this error??
Someone please can help? (PlanID-[Number] is marked incomplete. No entity can be associated to the plan)
NB: There is no missing setting related to this plan or any new plan with the same error.
Best answer by Suzanny Lloyd
Hi @Mohamed Nabil ,
Checked internally and we are current working on a fix for this issue. It will take a few weeks for the fix to be available.
Would advise if not already done so, to open a case with support so that it can be escalated and added to our form (  Form 9821 v11 B80 SP32 ) and we can then advise once fix is released and ready.
Kind regards,
Suzanny Lloyd
Hi @Mohamed Nabil ,
Kind regards,
Suzanny Lloyd
  • May 7, 2024
Thanks, Suzanny,
we have already opened a support case, otherwise i have CVLT environment with 11.34 with no issues which means the latest version not effected
  • September 16, 2025
Hi ​@Suzanny Lloyd  is this issue fixed ? I am on 11.40.16 and am getting it.
