Is it possible to auto assign media to specific (spare) Media Group pools base on barcode numbering
Even if ‘auto assignment’ is not possible, then when manually discovering media (eg for a single piece of unassigned/free media), can the ‘system’ not auto recognise the destination scratch pool base on barcode ranges
(Barcode ranges and patterns have been setup under media management)
Best answer by Collin Harper
Hello @YYZ
You can setup Barcode Patterns and then associate the Pattern to a Scratch Grou via the Scratch Group Properties. This will associate certain barcodes to their respective Storage Pools.
If I load 20 Tapes, the tapes are not ‘automatically’ being assigned to the correct Media Group according to their barcode
It appears there's still the need to ‘manually’ move the Tapes from default scratch to another ‘scratch’ media group
eg If I have tapes
AAA001
AAA002
BBB001
BBB003
I create two spare Media Groups “AAA-Group” and “BBB-Group” and I also have the default Scratch group
I set the barcode rules under media management
I load the tapes into the library - I would then hope AAA001/002 are auto assigned to Media Group AAA-Group etc. - Its this bit that still ‘seems’ to require the Tapes to be manually ‘moved’ from default scratch to either AAA-Group or BBB-Group
