Auto Discover DB instance options
  • June 12, 2023
  • 146 views
Forum|alt.badge.img+16
This is a quick one.
When applying the below key to disable Auto Discover of Instances, is there a way to limit that to only one client instead of at a Global level?
https://documentation.commvault.com/additionalsetting/details?name=nDisableAutoDiscoverInstancePostInstall
In my case, I have MySQL DBA’s who want Auto Discover on and the Oracle DBA’s who want it off. They don’t want to manually turn it off every time an Instance is added.
Best answer by Orazan
Good afternoon.  This global parameter should  disable auto discover for Oracle:
https://documentation.commvault.com/additionalsetting/details?name=%22DISABLE_ORACLE_RAC_AUTODISCOVER%22&id=8189
Here is a document on auto discovery for MySQL.  Please let me if you have any quesitons:
https://documentation.commvault.com/2022e/expert/19239_advanced_configuration_for_mysql.html#b19258_enabling_automatic_discovery_of_mysql_instances
Forum|alt.badge.img+18
  • June 19, 2023
  • Challenger
  • June 20, 2023
Hi Orazan
Thank you so much for both links.
Definitely will be useful to us.
Mauro
Nikos.Kyrm
  • Community All Star
  • April 14, 2026
Dear ​@Mauro , ​@Orazan  and all,
I recently encountered some unexpected behavior while deploying Oracle agents on an Oracle RAC (Exadata) cluster.
Immediately after the agent installation, Commvault not only automatically discovered and created the RAC instance (including connection strings), but it also automatically assigned it to a Storage Policy. This resulted in backups starting automatically the very next day without manual intervention from Commvault admins!
In our experience with Oracle RAC, we typically configure instances manually to ensure all specific parameters are correct. While I understand the "Auto-Discover" feature exists, I have two main concerns:
Auto-Discovery Accuracy: Is it standard for Commvault to fully populate connection strings for Exadata RAC environments so seamlessly?
Automatic Policy Assignment: Is it expected behavior for Commvault to automatically associate a newly discovered instance with a Storage Policy and begin scheduling backups without an administrator's approval? Could the reason for this automatic assignment be because a "Plan" was selected during the initial Oracle agent installation process?
I’d appreciate your insights on whether this is a specific default setting for newer Commvault versions (11.40+) or if there is a way to "discover only" without the automatic policy assignment.
Please for your feedback!
Nikos
Edit: BTW, to avoid unscheduled database configurations or backups, especially for Oracle RAC, these additional settings are the way to go to be on the safe side :)
1. nDisableAutoDiscoverInstancePostInstall
  • Purpose: Prevents automatic discovery of Oracle and Oracle RAC database instances immediately after installing the Oracle Agent (iDA) on a client.
  • When to Use: Set this registry key before installing the Oracle Agent if you want to avoid any automatic instance discovery right after installation.
2. DISABLE_ORACLE_RAC_AUTODISCOVER
  • Purpose: Disables ongoing, periodic automatic discovery of Oracle RAC instances (and their pseudo clients) in the CommServe.
  • When to Use: Set this additional setting if you want to stop the system from re-discovering and re-creating Oracle RAC pseudo clients and instances at any time, not just after installation.
Summary of Differences:
  • nDisableAutoDiscoverInstancePostInstall is used to prevent discovery only during the initial installation of the Oracle Agent.
  • DISABLE_ORACLE_RAC_AUTODISCOVER is used to prevent periodic and ongoing automatic discovery of Oracle RAC instances, regardless of installation timing.
