Auxiliary - Selective copy for specific job ?
  • March 27, 2023
  • 577 views
Nikos.Kyrm
Forum|alt.badge.img+16
Hello! Im looking for a way to Aux copy (via selective copy)? only for specific jobs.
For example: only a full VM job.
I know that I can “filter” aux copies for All Fulls, Daily Fulls, Monthly Fulls etc, but I need actually to aux copy only for specific jobs!
The source copy is a Disk and the destination is a Blob Storage.
Is there any way to do it?
I see an option to “Do not Automatically select jobs”, but Im not sure how it works.
Best answer by Chris Hollis
@Nikos.Kyrm
You would select ‘do not automatically select jobs’ as the copy option, you would then view the jobs on the source copy and manually select which ones you want to copy (right click the job > pick for copy)
This procedure is outlined here: https://documentation.commvault.com/2022e/expert/13912_manually_selecting_job_to_copy.html
Hope this helps!
Chris Hollis
  • March 27, 2023
@Nikos.Kyrm
Hope this helps!
Nikos.Kyrm
  • Community All Star
  • March 28, 2023
Dear @Chris Hollis thanks for your reply!
The key was step d. “In the Jobs in Storage Policy Advanced Filter Options dialog box, select the Jobs that will not be copied check box.”
After that, I’m able to aux copy only manual jobs.
Thanks again!
