Azure SQL bacpac exports not cleaning up
  • June 24, 2022
  • 208 views
Michael Woodward
Certified Expert
I have a customer that’s running Azure SQL backups, the backup process triggers the export of the database to a bacpac file in a dedicated storage account and then backs this up to a Cloud library.
I was under the impression that the data in the export location would only be transient as part of the backup process, however, looking at the storage account there are bacpac files going back for as long as we have had backups running for these Azure SQL accounts.
Is this the expected behaviour or should the backup process be cleaning up the staging location?
Best answer by Mike Struening
Sharing case resolution:
Solution:
- It seems like the older files in the storage account relate to backups during a period where many issues were occurring with that proxy machine.
- Customer cleared the files and will monitor.
Emils
  • June 27, 2022
Hi @Michael Woodward
The process should clean up once the backup is completed
the process goes...
  1. create copy of the DB since this will be transactionally consistent
  2. Export copy of the DB to Azure Storage account in .bacpac format
  3. Download that .bacpac file
  4. clean-up
We will need to determine what's in the export location and review the logs for any failures during clean-up.
I recommend raising a support ticket to review this issue further
Onno van den Berg
Forum|alt.badge.img+24
Could it be that the account is lacking permissions? Have you checked the logs?
Michael Woodward
Certified Expert
the process goes...
  4. clean-up
Thanks for this - it’s how I expected it to work as well, the .bacpac files that have been left behind are relatively old now and there’s no job logs that show me anything, logged a support ticket to confirm why this may be happening and if we can safely delete the files.
@Michael Woodward , can you share the case number so I can track it?
Solution:
