Backup MCC-A facing issue
  • March 31, 2022
  • 20 views
Hi Team
Please refer to the attached. We are receiving warning emails everyday regarding about the MCC-A. However MCC-B is fine. Could you kindly assist on this?
Thank you.
Best answer by Remi Sprangers
Hi Kian,
Looks like a port restriction on the client. Can you please open a case with support so they can check the logs why this client is not able to connect to the tape library?
Kind regards,
Remi
Hi Kian,
Kind regards,
Remi
