backup to tape and offsite.
  • March 25, 2022
  • 197 views
Forum|alt.badge.img+13
I am settings new copy to tape
the tape has 24 slots
I copy the last monthly full to tape. Retention is 1 year
I copy the last full off the year. Retention is 10 Years.
The customer want that when each time the data are copied to the tape, he must be alerted and manually take off the tape offsite
How do you deal with that ?
Thanks !
Best answer by Orazan
Good morning.  Have you looked at our Vault Tracker feature:
https://documentation.commvault.com/11.24/essential/107868_vault_tracker.html
Forum|alt.badge.img+18
  • March 25, 2022
  • March 25, 2022
Hi @Orazan
Thank you I will take a look !
