Best practices NDMP backup with large small files
  • Feb 28, 2024 1:17 PM UTC
  • 8 replies
  • 231 views
I am trying to NAS backup with NDMP agent but when i am running incr backup its taking to long or de backup faile. The volume have more then 14M small files.
What is best practice to backup it? Intellisnap maybe?
Best answer by dude
https://documentation.commvault.com/2023e/expert/cifs_shares.html
Hi @Egor Skepko ,
That is correct, we would recommend you use IntelliSnap.
https://documentation.commvault.com/2023e/expert/best_practices_for_ndmp_agent.html#use-intellisnap-to-improve-backup-performance-of-small-files
Sebastien
  • Feb 28, 2024 1:33 PM UTC
@Sebastien Merluzzi Sorry we are using HNAS, does it work on hnas aswell?
dude
Forum|alt.badge.img+20
  • Community All Star
  • Feb 28, 2024 6:00 PM UTC
CIFS share and File system agent in my experience will give you the best performance.
  • Feb 28, 2024 7:26 PM UTC
@dude do you have link how to configure it maybe?
dude
  • Feb 28, 2024 7:28 PM UTC
  • Feb 28, 2024 7:47 PM UTC
@dude working good with hnas 14.7?? and 14M small files.
  • Mar 4, 2024 3:23 PM UTC
And what is about iops and ms performance, because i tested out file scan phase my iops went to 8k instead of 800 and ms to 30 instead of 3
