BRBACKUP completed successfully with warnings
  • July 13, 2023
  • 656 views
Forum|alt.badge.img+5
We have three new SAP R3 system installed, beside several others. SAP for Oracle Agent installed and configured on all of these servers.
SAP for Oracle backups are running without any issue on most of our servers, but on the three new server, there is a warning. "Error Code: [18:104] Description: Some warnings might have been ignored for this job. Please check the backup.out log for details." Status:"Completed w/ one or more warnings" There are no skipped or failured folders or files.
In the suggested backup.out file I can find following: "BRBACKUP completed successfully with warnings" and "BRARCHIVE completed successfully with warnings", but nothing more about warnings.
Where could I find the reason of warning?
There are several "successfully" message, no "warning" in the log, only at the end of BRBACKUP or BRARCHIVE process. If SAP for Oracle backups can be completed without warnings on other servers, it should be on new ones also. I think.
Best answer by Rajiv
Hello @VBalazs
You can check BRTOOLS logs for more information and if there is any major error or warning, you can discuss with your DBA.
If you want to ignore the warnings and have the backups complete successfully, you can apply the below settings:
https://documentation.commvault.com/11.24/expert/21899_ignoring_brtools_warnings_for_sap_on_oracle_commcell_console_jobs_01.html
https://documentation.commvault.com/additionalsetting/details?name=%22sIGNOREBRTOOLSWARNINGS%22&id=4279
Best,
Rajiv Singal
Rajiv
  • July 13, 2023
Hello @VBalazs
Best,
Rajiv Singal
  • July 13, 2023
Hi @Rajiv
There are no error or warning messages, therefore “sIGNOREBRTOOLSWARNINGS” additional setting configured.
