Can our commserve, media agents and customers client run on OS platforms without oracle Java but using OpenJDK.
  • March 17, 2022
  • 913 views
hi I am enquiring if the 11.20 and 11.24 release version of backup server and client can run on OS platforms without oracle Java but using OpenJDK.
I can't seems to find any supportability document that mentions about the supportability of java edition
Best answer by Orazan
Good morning.  Commvault uses OpenJDK exclusively.  There will be no negative effect on Commvault if you were to remove Oracle Java.
https://documentation.commvault.com/11.24/expert/121377_third_party_applications_installed_by_commvault_installer.html
Forum|alt.badge.img+18
  • March 17, 2022
  • March 18, 2022
@Orazan , thanks for the reply , cheers
