CDR / Continuous Data Replication
  • January 26, 2022
  • 765 views
Marco Lachance
Explorer
Hi, I’m doing some test for a customer to replace Robot Copy with this feature. But isn’t clear what trigger is to replicate data ??
If we just add a small file at source couple of 100 KB the replication is not happening in the next following minutes !?
So was what will trigger the replication ?
Thank you
Best answer by MFasulo
Thanks for the ping!
The size i dont think is easily changed but docs has
Replication Logs - Overview (commvault.com)
  • At a specified time interval if there is not sufficient change activity to fill the log. This time interval is by default 15 minutes. If necessary, you can adjust this change interval. For step-by-step instructions, see Specify the CDR Log File Update Interval.
MFasulo
  • January 26, 2022
Its been about 7 years since I was using CDR, but there is a size (5mb) and a time component (i dont recall the minutes interval)    but its got to each one of those to replicate the data.
Marco Lachance
Explorer
@MFasulo Thank’s
So if the customer creates a lot of small files, the sum of those files need to reach at least 5mb to trigger the replication !?
Marco Lachance
Explorer
@MFasulo
And also can we tune the 5 Mb value?
@Marco Lachance , following up to see if you ever got an answer as I know @MFasulo will often chat offline about these topics :nerd:
Marco Lachance
Explorer
Nope, no news !
Thank you but it’s not a rush, the customer won’t go with it,
but I would like to know for my personal knowledge !
MFasulo
  • March 10, 2022
