Ceph object based storage for CEPH FS and RBD is supported? what are the different backup options availale for Ceph storage items like Ceph FS, RBD, S2 & S3.
Ceph object based storage for CEPH FS, S2 & RBD is supported
Hi
I'm not a Ceph expert but what I know is that you can create RBD backups. You will have to rely on native snapshots through native scheduling or through some custom made script to create snapshots. I assume you use RBD to run virtualized workloads, so in that case you might want to consider installing agents in the VM to create system backups. For CEPH FS you can use the network share option or a regular client with a FS client installed. RADOSGW can be protected using the object storage plugin.
Not sure about S2
