Change mount path after mirroring backup data using NetApp
  • May 17, 2023
  • 74 views
We have multiple backup data libraries (50TB+ each), we have mirrored one using storage mirroring techniques (NetApp). We’re planning on going into maintenance mode and changing the library mount path to new location after syncing and breaking mirror relationship.  Is there anything we’re missing or need to be aware of when modifying library backup data paths?
Best answer by Emils
Hi @Kelone
Please follow the instructions available on https://documentation.commvault.com/v11/essential/87486_modifying_disk_access_path.html
Once this is done, i would recommend running a Data Verification against all Policies associated to the library
Deduplicated data: https://documentation.commvault.com/2022e/expert/100399_data_verification_of_deduplicated_data.html
Job Based: https://documentation.commvault.com/2022e/expert/12372_getting_started_with_data_verification.html
Emils
  • May 17, 2023
Hi @Kelone
